Ana içeriğe geç
Sony BDP-BX510 Wi-Fi Module Replacement
Neye ihtiyacın var
  1. Sony BDP-BX510 Wi-Fi Module Replacement, Outer Cover: adım 1, 1 resimden 1.
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Wi-Fi Module Replacement: adım 2, 2 resimden 1. Sony BDP-BX510 Wi-Fi Module Replacement: adım 2, 2 resimden 2.
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Wi-Fi Module Replacement: adım 3, 2 resimden 1. Sony BDP-BX510 Wi-Fi Module Replacement: adım 3, 2 resimden 2.
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Wi-Fi Module Replacement: adım 4, 3 resimden 1. Sony BDP-BX510 Wi-Fi Module Replacement: adım 4, 3 resimden 2. Sony BDP-BX510 Wi-Fi Module Replacement: adım 4, 3 resimden 3.
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Wi-Fi Module Replacement: adım 5, 1 resimden 1.
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Wi-Fi Module Replacement, Port Board: adım 6, 1 resimden 1.
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Wi-Fi Module Replacement: adım 7, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Wi-Fi Module Replacement: adım 8, 1 resimden 1.
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Wi-Fi Module Replacement: adım 9, 1 resimden 1.
    • Remove the port board by simply pulling it away from the device.
  10. Sony BDP-BX510 Wi-Fi Module Replacement, Wi-Fi Module: adım 10, 1 resimden 1.
    • Pull the cable that attaches the Wi-Fi module to the motherboard.
    • The cable will be hard to remove, so pull hard but carefully.
  11. Sony BDP-BX510 Wi-Fi Module Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the single 5mm screw that holds Wi-Fi module to the device.
  12. Sony BDP-BX510 Wi-Fi Module Replacement: adım 12, 1 resimden 1.
    • Carefully remove the Wi-Fi module from the device.
    • Avoid getting fingerprints on the module.
Sonuç
Niki Ngosi
375 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 263
