Ana içeriğe geç
Sony BDP-BX520 Bluetooth Module Replacement
Neye ihtiyacın var
  1. Sony BDP-BX520 Bluetooth Module Replacement, Disc Tray Cover: adım 1, 1 resimden 1.
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP-BX520 Bluetooth Module Replacement: adım 2, 1 resimden 1.
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP-BX520 Bluetooth Module Replacement: adım 3, 1 resimden 1.
    • Close the disc tray, then power off and unplug the Blu-Ray player.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP-BX520 Bluetooth Module Replacement, Top Case: adım 4, 1 resimden 1.
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP-BX520 Bluetooth Module Replacement: adım 5, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement: adım 5, 2 resimden 2.
    • Gently pull the top case back to remove it from the Blu-Ray player.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP-BX520 Bluetooth Module Replacement, Front Panel: adım 6, 1 resimden 1.
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP-BX520 Bluetooth Module Replacement: adım 7, 1 resimden 1.
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Sony BDP-BX520 Bluetooth Module Replacement: adım 8, 1 resimden 1.
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
    FixBot'a Sor
    Yorum Ekle
  9. Sony BDP-BX520 Bluetooth Module Replacement: adım 9, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement: adım 9, 2 resimden 2.
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
    FixBot'a Sor
    Yorum Ekle
  10. Sony BDP-BX520 Bluetooth Module Replacement, Port Board: adım 10, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement, Port Board: adım 10, 2 resimden 2.
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
    FixBot'a Sor
    Yorum Ekle
  11. Sony BDP-BX520 Bluetooth Module Replacement: adım 11, 1 resimden 1.
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
    FixBot'a Sor
    Yorum Ekle
  12. Sony BDP-BX520 Bluetooth Module Replacement: adım 12, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement: adım 12, 2 resimden 2.
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
    FixBot'a Sor
    Yorum Ekle
  13. Sony BDP-BX520 Bluetooth Module Replacement: adım 13, 1 resimden 1.
    • Carefully pull the port board free from the Blu-Ray player.
    FixBot'a Sor
    Yorum Ekle
  14. Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: adım 14, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: adım 14, 2 resimden 2.
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Sony BDP-BX520 Bluetooth Module Replacement: adım 15, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the silver 8 mm screw attaching the Bluetooth module to the front of the case.
    FixBot'a Sor
    Yorum Ekle
  16. Sony BDP-BX520 Bluetooth Module Replacement: adım 16, 2 resimden 1. Sony BDP-BX520 Bluetooth Module Replacement: adım 16, 2 resimden 2.
    • Remove the Bluetooth module from the case.
    • Make sure to only touch the sides of the Bluetooth module when removing it from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Gregory Pellegrino
405 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G41
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 682
