Ana içeriğe geç
Sony BDP-BX520 Disc Reader Replacement
Neye ihtiyacın var
  1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: adım 1, 1 resimden 1.
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP-BX520 Disc Reader Replacement: adım 2, 1 resimden 1.
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP-BX520 Disc Reader Replacement: adım 3, 1 resimden 1.
    • Close the disc tray, then power off and unplug the Blu-Ray player.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP-BX520 Disc Reader Replacement, Top Case: adım 4, 1 resimden 1.
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP-BX520 Disc Reader Replacement: adım 5, 2 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 5, 2 resimden 2.
    • Gently pull the top case back to remove it from the Blu-Ray player.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP-BX520 Disc Reader Replacement, Front Panel: adım 6, 1 resimden 1.
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP-BX520 Disc Reader Replacement: adım 7, 1 resimden 1.
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Sony BDP-BX520 Disc Reader Replacement: adım 8, 1 resimden 1.
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
    FixBot'a Sor
    Yorum Ekle
  9. Sony BDP-BX520 Disc Reader Replacement: adım 9, 2 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 9, 2 resimden 2.
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
    FixBot'a Sor
    Yorum Ekle
  10. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: adım 10, 1 resimden 1.
    • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
    • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
    FixBot'a Sor
    Yorum Ekle
  11. Sony BDP-BX520 Disc Reader Replacement: adım 11, 1 resimden 1.
    • Eject the disc tray by pushing the left button on the front of the device.
    • Unplug the device once the disc tray is open.
    FixBot'a Sor
    Yorum Ekle
  12. Sony BDP-BX520 Disc Reader Replacement: adım 12, 1 resimden 1.
    • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
    FixBot'a Sor
    Yorum Ekle
  13. Sony BDP-BX520 Disc Reader Replacement: adım 13, 2 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 13, 2 resimden 2.
    • Once the clips are free, lift the top cover of the disc tray up.
    • This should take minimal force.
    FixBot'a Sor
    Yorum Ekle
  14. Sony BDP-BX520 Disc Reader Replacement: adım 14, 1 resimden 1.
    • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
    FixBot'a Sor
    Yorum Ekle
  15. Sony BDP-BX520 Disc Reader Replacement: adım 15, 3 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 15, 3 resimden 2. Sony BDP-BX520 Disc Reader Replacement: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
    • Once free the white 24 pin ribbon should slip right out.
    FixBot'a Sor
    Yorum Ekle
  16. Sony BDP-BX520 Disc Reader Replacement: adım 16, 2 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 16, 2 resimden 2.
    • Carefully lift up the disc reader. It is still attached by a cable underneath!
    FixBot'a Sor
    Yorum Ekle
  17. Sony BDP-BX520 Disc Reader Replacement: adım 17, 2 resimden 1. Sony BDP-BX520 Disc Reader Replacement: adım 17, 2 resimden 2.
    • Gently pull out the white 13 pin cable from the disc reader.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Smit
243 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G41
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 32
Her zaman: 1,632
