Ana içeriğe geç
Sony BDP-BX520 Disc Tray Replacement
Neye ihtiyacın var
  1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray Cover: adım 1, 1 resimden 1.
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Disc Tray Replacement: adım 2, 1 resimden 1.
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Disc Tray Replacement: adım 3, 1 resimden 1.
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Disc Tray Replacement, Top Case: adım 4, 1 resimden 1.
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Disc Tray Replacement: adım 5, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 5, 2 resimden 2.
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Disc Tray Replacement, Front Panel: adım 6, 1 resimden 1.
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Disc Tray Replacement: adım 7, 1 resimden 1.
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Disc Tray Replacement: adım 8, 1 resimden 1.
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Disc Tray Replacement: adım 9, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 9, 2 resimden 2.
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Disc Tray Replacement, Disc Tray: adım 10, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray: adım 10, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
  11. Sony BDP-BX520 Disc Tray Replacement: adım 11, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 11, 2 resimden 2.
    • Pull the medium-sized 9 pin ribbon cable out of its connector on the motherboard.
  12. Sony BDP-BX520 Disc Tray Replacement: adım 12, 3 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 12, 3 resimden 2. Sony BDP-BX520 Disc Tray Replacement: adım 12, 3 resimden 3.
    • Using tweezers, lift up the tab of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of its connector.
  13. Sony BDP-BX520 Disc Tray Replacement: adım 13, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 13, 2 resimden 2.
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
  14. Sony BDP-BX520 Disc Tray Replacement: adım 14, 2 resimden 1. Sony BDP-BX520 Disc Tray Replacement: adım 14, 2 resimden 2.
    • Slide the disk tray out from under the tabs on the case holding it down while lifting it out of the case.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Gregory Pellegrino
405 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G41
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
tomcerecedes - Yanıt
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
Susan Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 7,398
