Ana içeriğe geç
Sony BDP-BX520 Port Board Replacement
Neye ihtiyacın var
  1. Sony BDP-BX520 Port Board Replacement, Disc Tray Cover: adım 1, 1 resimden 1.
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Port Board Replacement: adım 2, 1 resimden 1.
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Port Board Replacement: adım 3, 1 resimden 1.
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Port Board Replacement, Front Panel: adım 4, 1 resimden 1.
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  5. Sony BDP-BX520 Port Board Replacement: adım 5, 1 resimden 1.
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  6. Sony BDP-BX520 Port Board Replacement: adım 6, 1 resimden 1.
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  7. Sony BDP-BX520 Port Board Replacement: adım 7, 2 resimden 1. Sony BDP-BX520 Port Board Replacement: adım 7, 2 resimden 2.
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  8. Sony BDP-BX520 Port Board Replacement, Port Board: adım 8, 2 resimden 1. Sony BDP-BX520 Port Board Replacement, Port Board: adım 8, 2 resimden 2.
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  9. Sony BDP-BX520 Port Board Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  10. Sony BDP-BX520 Port Board Replacement: adım 10, 2 resimden 1. Sony BDP-BX520 Port Board Replacement: adım 10, 2 resimden 2.
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  11. Sony BDP-BX520 Port Board Replacement: adım 11, 1 resimden 1.
    • Carefully pull the port board free from the Blu-Ray player.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Collier
352 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G41
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 336
