Ana içeriğe geç
Sony BDP-BX620 Bluetooth Module Replacement
Neye ihtiyacın var
  1. Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: adım 1, 2 resimden 1. Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: adım 1, 2 resimden 2.
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
    FixBot'a Sor
  2. Sony BDP-BX620 Bluetooth Module Replacement: adım 2, 2 resimden 1. Sony BDP-BX620 Bluetooth Module Replacement: adım 2, 2 resimden 2.
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
    FixBot'a Sor
  3. Sony BDP-BX620 Bluetooth Module Replacement: adım 3, 3 resimden 1. Sony BDP-BX620 Bluetooth Module Replacement: adım 3, 3 resimden 2. Sony BDP-BX620 Bluetooth Module Replacement: adım 3, 3 resimden 3.
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
    FixBot'a Sor
  4. Sony BDP-BX620 Bluetooth Module Replacement, Port Board: adım 4, 2 resimden 1. Sony BDP-BX620 Bluetooth Module Replacement, Port Board: adım 4, 2 resimden 2.
    • Now, spot the large ribbon cable that connects between the motherboard and the port board.
    • Remove the cable by pulling upwards.
    • Be careful when pulling upwards on the ribbon cable. Too much force can cause it to rip.
    FixBot'a Sor
  5. Sony BDP-BX620 Bluetooth Module Replacement: adım 5, 1 resimden 1.
    • Use your Phillips screwdriver to take out the silver screw holding in the port board.
    FixBot'a Sor
  6. Sony BDP-BX620 Bluetooth Module Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Now use the tweezers to unclip the portboard on the side.
    FixBot'a Sor
  7. Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: adım 7, 2 resimden 1. Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: adım 7, 2 resimden 2.
    • Now, pull the small ribbon cable that connects between the motherboard and the Bluetooth module.
    • Be careful to not pull too hard or the ribbon cable will rip.
    FixBot'a Sor
  8. Sony BDP-BX620 Bluetooth Module Replacement: adım 8, 1 resimden 1.
    • Use your Phillips screwdriver to remove the silver screw holding the Bluetooth module in place.
    FixBot'a Sor
  9. Sony BDP-BX620 Bluetooth Module Replacement: adım 9, 1 resimden 1.
    • Lift to remove the bluetooth module from the device.
    • To prevent damage, always hold it on the sides.
    FixBot'a Sor
Sonuç
Zachery Zavala
175 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 52
Her zaman: 489
