Ana içeriğe geç
Sony BDP-BX620 Power Module Replacement
Neye ihtiyacın var
  1. Sony BDP-BX620 Power Module Replacement, Outer Cover: adım 1, 2 resimden 1. Sony BDP-BX620 Power Module Replacement, Outer Cover: adım 1, 2 resimden 2.
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
    FixBot'a Sor
  2. Sony BDP-BX620 Power Module Replacement: adım 2, 2 resimden 1. Sony BDP-BX620 Power Module Replacement: adım 2, 2 resimden 2.
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
    FixBot'a Sor
  3. Sony BDP-BX620 Power Module Replacement: adım 3, 3 resimden 1. Sony BDP-BX620 Power Module Replacement: adım 3, 3 resimden 2. Sony BDP-BX620 Power Module Replacement: adım 3, 3 resimden 3.
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
    FixBot'a Sor
  4. Sony BDP-BX620 Power Module Replacement, Power Module: adım 4, 1 resimden 1.
    • Gently pull on up on the power cord to unlatch it from the metal body of the device.
    FixBot'a Sor
  5. Sony BDP-BX620 Power Module Replacement: adım 5, 1 resimden 1.
    • Remove the cable connecting the Power Port to the Motherboard by pulling up.
    • It may be difficult to remove. Pull from the plastic part and not the wiring to prevent the wiring from breaking.
    FixBot'a Sor
  6. Sony BDP-BX620 Power Module Replacement: adım 6, 1 resimden 1.
    • Remove both screws using the Phillips screw driver.
    FixBot'a Sor
  7. Sony BDP-BX620 Power Module Replacement: adım 7, 1 resimden 1.
    • Lift the Power Module up from the side. See picture.
    • Pull up and away to remove the Power Module
    FixBot'a Sor
Sonuç
Axel Cruz Jimenez
207 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 469
