Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
Slide the top panel off towards the back of the device.
Remove the top panel.
Unclip the plastic tags from the bottom of the device.
Unclip the plastic tags from the sides of the device.
Slide the front panel off.
Keep the back side up and facing towards you.
Carefully disconnect the blue ribbon connecting the port board and motherboard.
Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
Use a Phillips #2 screwdriver to remove the 7mm screw from the Wi-Fi module.
