Ana içeriğe geç
Sony BDP-S3700 Disc Drive Replacement
Neye ihtiyacın var
  1. Sony BDP-S3700 Disc Drive Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3700 Disc Drive Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP-S3700 Disc Drive Replacement: adım 2, 2 resimden 1. Sony BDP-S3700 Disc Drive Replacement: adım 2, 2 resimden 2.
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP-S3700 Disc Drive Replacement: adım 3, 2 resimden 1. Sony BDP-S3700 Disc Drive Replacement: adım 3, 2 resimden 2.
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP-S3700 Disc Drive Replacement: adım 4, 1 resimden 1.
    • Once all the clips are open, slide the front outer housing out.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP-S3700 Disc Drive Replacement, Disc Drive: adım 5, 3 resimden 1. Sony BDP-S3700 Disc Drive Replacement, Disc Drive: adım 5, 3 resimden 2. Sony BDP-S3700 Disc Drive Replacement, Disc Drive: adım 5, 3 resimden 3.
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP-S3700 Disc Drive Replacement: adım 6, 2 resimden 1. Sony BDP-S3700 Disc Drive Replacement: adım 6, 2 resimden 2.
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP-S3700 Disc Drive Replacement: adım 7, 1 resimden 1.
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Luiz Barreto
645 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G1
4 Üyeler
2Kılavuz Yorumları
do you know how I can find a replacement power socket for the pcb on a sony bluray player like the one on this item?
It is the yellow colored socket on this model and still used on most Sony players still in production that use an external AC adapter.
cmfic1 - Yanıt Paylaş
Bei mein dvd Player geht das Netflix nicht und ich habe keine dvd da zu bekommen
Ramona Piekarski - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 51
Her zaman: 5,863
