Ana içeriğe geç
Sony BDP-S3700 Motherboard Replacement
Neye ihtiyacın var
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3700 Motherboard Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: adım 2, 2 resimden 1. Sony BDP-S3700 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: adım 3, 2 resimden 1. Sony BDP-S3700 Motherboard Replacement: adım 3, 2 resimden 2.
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: adım 4, 1 resimden 1.
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: adım 5, 3 resimden 1. Sony BDP-S3700 Motherboard Replacement, Disc Drive: adım 5, 3 resimden 2. Sony BDP-S3700 Motherboard Replacement, Disc Drive: adım 5, 3 resimden 3.
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: adım 6, 2 resimden 1. Sony BDP-S3700 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Sony BDP-S3700 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: adım 9, 3 resimden 1. Sony BDP-S3700 Motherboard Replacement: adım 9, 3 resimden 2. Sony BDP-S3700 Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: adım 10, 3 resimden 1. Sony BDP-S3700 Motherboard Replacement: adım 10, 3 resimden 2. Sony BDP-S3700 Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: adım 11, 1 resimden 1.
    • Carefully lift and pull the motherboard forward to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Luiz Barreto
627 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G1
4 Üyeler
2 Yorum
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - Yanıt
Same problem here.
Julian Robbins -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 1,480
