Ana içeriğe geç
Sony BDP-S3700 Wi-Fi Module Replacement
Neye ihtiyacın var
  1. Sony BDP-S3700 Wi-Fi Module Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3700 Wi-Fi Module Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Wi-Fi Module Replacement: adım 2, 2 resimden 1. Sony BDP-S3700 Wi-Fi Module Replacement: adım 2, 2 resimden 2.
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Wi-Fi Module Replacement: adım 3, 2 resimden 1. Sony BDP-S3700 Wi-Fi Module Replacement: adım 3, 2 resimden 2.
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Wi-Fi Module Replacement: adım 4, 1 resimden 1.
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Wi-Fi Module Replacement, Port Board: adım 5, 1 resimden 1.
    • Flip the Blu-ray back up
    • Remove the ribbon connecting the port board to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Wi-Fi Module Replacement: adım 6, 1 resimden 1.
    • Use the PH1 to remove the 7mm screw on the port board.
  7. Sony BDP-S3700 Wi-Fi Module Replacement: adım 7, 1 resimden 1.
    • Remove the port board.
  8. Sony BDP-S3700 Wi-Fi Module Replacement, Wi-Fi Module: adım 8, 1 resimden 1.
    • Remove the ribbon connecting the Wi-Fi module to the motherboard.
  9. Sony BDP-S3700 Wi-Fi Module Replacement: adım 9, 1 resimden 1.
    • Use the PH1 screwdriver to remove the 7mm screw on the module.
  10. Sony BDP-S3700 Wi-Fi Module Replacement: adım 10, 1 resimden 1.
    • Remove the Wi-Fi module
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Luiz Barreto
627 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2017 USF Tampa, Team 12-1, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 698
