Giriş
Is your camcorder failing to turn on? Consider using this guide to replace the power button of your device.
Neye ihtiyacın var
Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
Slide the RELEASE switch up to bring the hand drip down.
Remove the two screws (2mm x 6mm) on either side of the FILTER switch on the black and white side of the Betamovie using the Phillips #0 screwdriver.
Remove the two screws on the bottom of the camera on the side with the black and white face using the same screwdriver.
Remove the screws on the bottom of the back of the camera with the same screwdriver.
