Giriş
Every battery runs out of power eventually after many uses. This guide will show you how to easily replace the battery on your Sonly Bloggie 3D.
Neye ihtiyacın var
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Bu adımda kullanılan alet:Tweezers$4.99
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
1Rehber Yorum
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
