Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Use a plastic opening tool to pry the cover open.
After the the cover is partly open as shown, remove the cover with your hands.
Bu adımda kullanılan alet:Tweezers$4.99-
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Use a plastic opening tool to loosen the back cover off the device.
Once the back cover is loose, remove it gently by hand.
Bir Yorum
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
