Ana içeriğe geç
Giriş
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  4. Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
    • Detach the board from the ZIF connector using pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Sonuç
Robert Tam
6 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G12
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 281
