Ana içeriğe geç
Sony Bloggie 3D Player On/Off Buttons Replacement
Neye ihtiyacın var
  1. Sony Bloggie 3D Player On/Off Buttons Replacement, Front Cover: adım 1, 1 resimden 1.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player On/Off Buttons Replacement: adım 2, 2 resimden 1. Sony Bloggie 3D Player On/Off Buttons Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: adım 3, 2 resimden 1. Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player On/Off Buttons Replacement: adım 4, 2 resimden 1. Sony Bloggie 3D Player On/Off Buttons Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player On/Off Buttons Replacement, On/Off Buttons: adım 5, 1 resimden 1.
    • Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
  6. Sony Bloggie 3D Player On/Off Buttons Replacement: adım 6, 1 resimden 1.
    • Unclip the two plastic buttons with the spudger tool.
    • The buttons each have a spring under them that will fall off, be careful not to lose them.
Sonuç
Fred Saucedo
6 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G12
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 392
