Ana içeriğe geç
Sony CCD-TR81 Microphone Casing Replacement
Neye ihtiyacın var
  1. Sony CCD-TR81 Microphone Casing Replacement, Disassembling Sony CCD-TR81 Battery: adım 1, 1 resimden 1.
    • Lift viewfinder to access battery pack.
  2. Sony CCD-TR81 Microphone Casing Replacement: adım 2, 2 resimden 1. Sony CCD-TR81 Microphone Casing Replacement: adım 2, 2 resimden 2.
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. Sony CCD-TR81 Microphone Casing Replacement: adım 3, 1 resimden 1.
    • Pull the battery pack out of the video camera.
  4. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: adım 4, 3 resimden 1. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: adım 4, 3 resimden 2. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: adım 4, 3 resimden 3.
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
  5. Sony CCD-TR81 Microphone Casing Replacement: adım 5, 2 resimden 1. Sony CCD-TR81 Microphone Casing Replacement: adım 5, 2 resimden 2.
    • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
    • Remove the single 4.5 mm screw from the backside.
  6. Sony CCD-TR81 Microphone Casing Replacement: adım 6, 1 resimden 1.
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
  7. Sony CCD-TR81 Microphone Casing Replacement: adım 7, 1 resimden 1.
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
  8. Sony CCD-TR81 Microphone Casing Replacement: adım 8, 1 resimden 1.
    • Pull the bottom part of the case away from the camera.
  9. Sony CCD-TR81 Microphone Casing Replacement: adım 9, 1 resimden 1.
    • Remove the three 4.5 mm screws from the right face of the video camera.
  10. Sony CCD-TR81 Microphone Casing Replacement: adım 10, 1 resimden 1.
    • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
  11. Sony CCD-TR81 Microphone Casing Replacement: adım 11, 1 resimden 1.
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
  12. Sony CCD-TR81 Microphone Casing Replacement: adım 12, 1 resimden 1.
    • Remove two remaining 3.6 mm case screws from the front of the camera.
  13. Sony CCD-TR81 Microphone Casing Replacement: adım 13, 2 resimden 1. Sony CCD-TR81 Microphone Casing Replacement: adım 13, 2 resimden 2.
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
  14. Sony CCD-TR81 Microphone Casing Replacement, Microphone Casing: adım 14, 1 resimden 1.
    • Unscrew the blue screw behind microphone and remove it from the video camera 1x3.6mm.
  15. Sony CCD-TR81 Microphone Casing Replacement: adım 15, 1 resimden 1.
    • Pull the circuit board up and away from the microphone case.
  16. Sony CCD-TR81 Microphone Casing Replacement: adım 16, 1 resimden 1.
    • Pull up metal brackets with plastic removal tool.
  17. Sony CCD-TR81 Microphone Casing Replacement: adım 17, 1 resimden 1.
    • With the plastic removal tool, pry up the microphone housing units. This will allow access to the camcorder microphone.
Sonuç
Austin Winther
4 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-25, Maness Winter 2011 Cal Poly, Team 11-25, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G25
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,357
