Ana içeriğe geç
Sony CDX-GT540UI CD Drive Replacement
Neye ihtiyacın var
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: adım 1, 1 resimden 1.
    • Locate face-plate eject button.
    FixBot'a Sor
    Yorum Ekle
  2. Sony CDX-GT540UI CD Drive Replacement: adım 2, 2 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 2, 2 resimden 2.
    • Press the eject button.
    • Remove the face-plate.
    FixBot'a Sor
    Yorum Ekle
  3. Sony CDX-GT540UI CD Drive Replacement: adım 3, 3 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 3, 3 resimden 2. Sony CDX-GT540UI CD Drive Replacement: adım 3, 3 resimden 3.
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    FixBot'a Sor
    Yorum Ekle
  4. Sony CDX-GT540UI CD Drive Replacement: adım 4, 2 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 4, 2 resimden 2.
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
    FixBot'a Sor
    Yorum Ekle
  5. Sony CDX-GT540UI CD Drive Replacement: adım 5, 1 resimden 1.
    • Remove front panel.
    FixBot'a Sor
    Yorum Ekle
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: adım 6, 1 resimden 1.
    • Locate back panel.
    FixBot'a Sor
    Yorum Ekle
  7. Sony CDX-GT540UI CD Drive Replacement: adım 7, 3 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 7, 3 resimden 2. Sony CDX-GT540UI CD Drive Replacement: adım 7, 3 resimden 3.
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
    FixBot'a Sor
    Yorum Ekle
  8. Sony CDX-GT540UI CD Drive Replacement: adım 8, 1 resimden 1.
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
    FixBot'a Sor
    Yorum Ekle
  9. Sony CDX-GT540UI CD Drive Replacement: adım 9, 1 resimden 1.
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
    FixBot'a Sor
    Yorum Ekle
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: adım 10, 1 resimden 1.
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
    FixBot'a Sor
    Yorum Ekle
  11. Sony CDX-GT540UI CD Drive Replacement: adım 11, 2 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 11, 2 resimden 2.
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
    FixBot'a Sor
    Yorum Ekle
  12. Sony CDX-GT540UI CD Drive Replacement: adım 12, 2 resimden 1. Sony CDX-GT540UI CD Drive Replacement: adım 12, 2 resimden 2.
    • Remove top panel.
    FixBot'a Sor
    Yorum Ekle
  13. Sony CDX-GT540UI CD Drive Replacement: adım 13, 1 resimden 1.
    • Pull up CD drive slightly.
    FixBot'a Sor
    Yorum Ekle
  14. Sony CDX-GT540UI CD Drive Replacement: adım 14, 1 resimden 1.
    • Disconnect motherboard connection.
    FixBot'a Sor
    Yorum Ekle
  15. Sony CDX-GT540UI CD Drive Replacement: adım 15, 1 resimden 1.
    • Remove CD drive.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Odelkys Marquez
1.139 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G2
3 Üyeler
1Rehber Yorum
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,134
