Giriş
This will show one how to remove and replace the CD drive.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
Neye ihtiyacın var
Remove one 9.5mm Phillips #00 screw.
Rotate device 180 degrees and repeat step.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
