Giriş
This guide will show how to remove and replace the face-plate eject lever on the device.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
  1. Locate face-plate eject button.
    • Locate face-plate eject button.
  2. Press the eject button. Remove the face-plate.
    • Press the eject button.
    • Remove the face-plate.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove two 4.9mm Phillips #00screws on the front of the device. Remove two 7.5mm Phillips #00screws on the front of the device. When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  5. Rotate device 90 degrees to either side. Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  6. Remove front panel.
    • Remove front panel.
  7. Remove the eject lever.
    • Remove the eject lever.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Odelkys Marquez
953 İtibar
7 adet Kılavuz yazıldı
Takım
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G2
3 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 9
Her zaman: 1,239
