Ana içeriğe geç
Sony CDX-GT540UI Front Panel Replacement
Neye ihtiyacın var
  1. Sony CDX-GT540UI Front Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Locate face-plate eject button.
    FixBot'a Sor
    Yorum Ekle
  2. Sony CDX-GT540UI Front Panel Replacement: adım 2, 2 resimden 1. Sony CDX-GT540UI Front Panel Replacement: adım 2, 2 resimden 2.
    • Press the eject button.
    • Remove the face-plate.
    FixBot'a Sor
    Yorum Ekle
  3. Sony CDX-GT540UI Front Panel Replacement: adım 3, 3 resimden 1. Sony CDX-GT540UI Front Panel Replacement: adım 3, 3 resimden 2. Sony CDX-GT540UI Front Panel Replacement: adım 3, 3 resimden 3.
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    FixBot'a Sor
    Yorum Ekle
  4. Sony CDX-GT540UI Front Panel Replacement: adım 4, 2 resimden 1. Sony CDX-GT540UI Front Panel Replacement: adım 4, 2 resimden 2.
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
    FixBot'a Sor
    Yorum Ekle
  5. Sony CDX-GT540UI Front Panel Replacement: adım 5, 1 resimden 1.
    • Remove front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Odelkys Marquez
1.139 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 3,288
