Ana içeriğe geç
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: adım 1, 1 resimden 1.
    • Locate the clip on the wiring harness.
    FixBot'a Sor
    Yorum Ekle
  2. Sony CDX-GT540UI Fuse Replacement: adım 2, 2 resimden 1. Sony CDX-GT540UI Fuse Replacement: adım 2, 2 resimden 2.
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
    FixBot'a Sor
    Yorum Ekle
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: adım 3, 1 resimden 1.
    • Once you have removed the wiring harness.
    • Locate the fuse.
    FixBot'a Sor
    Yorum Ekle
  4. Sony CDX-GT540UI Fuse Replacement: adım 4, 1 resimden 1.
    • Using your index finger and thumb on either side of the fuse.
    FixBot'a Sor
    Yorum Ekle
  5. Sony CDX-GT540UI Fuse Replacement: adım 5, 1 resimden 1.
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Odelkys Marquez
1.139 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G2
3 Üyeler
1Rehber Yorum
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 70
Her zaman: 10,679
