Giriş
This guide will show how to replace a motherboard. The motherboard could be causing faulty display, not turning on, and bad sound quality on a continuous basis.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
Neye ihtiyacın var
Remove two 4.9mm Phillips #00screws on the front of the device.
Remove two 7.5mm Phillips #00screws on the front of the device.
The screws in red do not seem to need to be removed unless you are trying to replace the eject lever. If you're not trying to replace the lever, it adds an unnecessary complication to putting it back together.
Remove one 9.5mm Phillips #00 screw.
Rotate device 180 degrees and repeat step.
4 farklı kişi bu kılavuzu tamamladı.
