Ana içeriğe geç
Sony CFD-8 Front Panel Replacement
Neye ihtiyacın var
  1. Sony CFD-8 Front Panel Replacement, Battery: adım 1, 3 resimden 1. Sony CFD-8 Front Panel Replacement, Battery: adım 1, 3 resimden 2. Sony CFD-8 Front Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
    FixBot'a Sor
    Yorum Ekle
  2. Sony CFD-8 Front Panel Replacement: adım 2, 2 resimden 1. Sony CFD-8 Front Panel Replacement: adım 2, 2 resimden 2.
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    FixBot'a Sor
    Yorum Ekle
  3. Sony CFD-8 Front Panel Replacement, Front Panel: adım 3, 3 resimden 1. Sony CFD-8 Front Panel Replacement, Front Panel: adım 3, 3 resimden 2. Sony CFD-8 Front Panel Replacement, Front Panel: adım 3, 3 resimden 3.
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
    FixBot'a Sor
    Yorum Ekle
  4. Sony CFD-8 Front Panel Replacement: adım 4, 2 resimden 1. Sony CFD-8 Front Panel Replacement: adım 4, 2 resimden 2.
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
    FixBot'a Sor
    Yorum Ekle
  5. Sony CFD-8 Front Panel Replacement: adım 5, 3 resimden 1. Sony CFD-8 Front Panel Replacement: adım 5, 3 resimden 2. Sony CFD-8 Front Panel Replacement: adım 5, 3 resimden 3.
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew Kleve
271 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G38
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 4,198
