Ana içeriğe geç
Sony CFD-8 Speaker Replacement
Neye ihtiyacın var
  1. Sony CFD-8 Speaker Replacement, Front Panel: adım 1, 3 resimden 1. Sony CFD-8 Speaker Replacement, Front Panel: adım 1, 3 resimden 2. Sony CFD-8 Speaker Replacement, Front Panel: adım 1, 3 resimden 3.
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  2. Sony CFD-8 Speaker Replacement: adım 2, 2 resimden 1. Sony CFD-8 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  3. Sony CFD-8 Speaker Replacement: adım 3, 3 resimden 1. Sony CFD-8 Speaker Replacement: adım 3, 3 resimden 2. Sony CFD-8 Speaker Replacement: adım 3, 3 resimden 3.
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  4. Sony CFD-8 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Sony CFD-8 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
  5. Sony CFD-8 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the speakers from the front panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Liam Kirsh
197 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G38
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 3,293
