Ana içeriğe geç
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
Neye ihtiyacın var
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: adım 1, 1 resimden 1.
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: adım 2, 3 resimden 1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: adım 2, 3 resimden 2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: adım 2, 3 resimden 3.
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 1,850
