Ana içeriğe geç
Sony CFS-204 Radio Cassette-Corder Speaker Replacement
Neye ihtiyacın var
  1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: adım 1, 1 resimden 1.
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: adım 2, 3 resimden 1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: adım 2, 3 resimden 2. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: adım 2, 3 resimden 3.
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: adım 3, 3 resimden 1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: adım 3, 3 resimden 2. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: adım 3, 3 resimden 3.
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Opening: adım 4, 1 resimden 1.
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: adım 5, 2 resimden 1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: adım 5, 2 resimden 2.
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: adım 6, 2 resimden 1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: adım 6, 2 resimden 2.
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
  7. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Glue: adım 7, 1 resimden 1.
    • Carefully slice the glue holding the speaker wire at the top right corner of the front face with a sharp tool or a knife to separate the wire from the case.
    • The wire can be tucked into its original location without re-gluing it.
  8. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Speaker: adım 8, 1 resimden 1.
    • Remove the 2 screws (10 mm in length) located on the corners of the speaker with the Phillips #2 screwdriver.
    • There are 4 screw positions; however, our radio only had screws in two of the positions on each speaker.
    • Repeat the process for the second speaker if you need to replace both speakers.
  9. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: adım 9, 1 resimden 1.
    • Lift the speakers out of the front face of the radio to complete the removal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,681
