Giriş
This guide will demonstrate how to access the TONE knob or VOLUME knob and replace it.
Neye ihtiyacın var
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
Push upwards against bottom edge of the knob connection with a flat head screwdriver until the knob pops off.
3 farklı kişi bu kılavuzu tamamladı.
