Giriş
Use this guide if the speakers do not turn on and you think it is because the power cord in the subwoofer is broken.
Neye ihtiyacın var
Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
Once all of the screws are removed, the cover can be taken off using a metal spudger.
Remove four 8 mm Phillips #2 screws.
Detach the air tube from the side panel.
