Ana içeriğe geç
Sony CPF-IP001 Power Plug Replacement
Neye ihtiyacın var
  1. Sony CPF-IP001 Power Plug Replacement, Power Plug: adım 1, 3 resimden 1. Sony CPF-IP001 Power Plug Replacement, Power Plug: adım 1, 3 resimden 2. Sony CPF-IP001 Power Plug Replacement, Power Plug: adım 1, 3 resimden 3.
    • The Sony Cradle Audio System will have 14 XXXX type of screws located on the bottom of the device.
    • Using a Phillips #2 screwdriver, remove all 14 screws.
  2. Sony CPF-IP001 Power Plug Replacement: adım 2, 3 resimden 1. Sony CPF-IP001 Power Plug Replacement: adım 2, 3 resimden 2. Sony CPF-IP001 Power Plug Replacement: adım 2, 3 resimden 3.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    • There are 8 more XXXX screws holding the circuit board in place that will need to be removed.
    • Once the screws are removed, a plastic spudger can be used to carefully move the circuit board away from the device.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Power Plug Replacement: adım 3, 2 resimden 1. Sony CPF-IP001 Power Plug Replacement: adım 3, 2 resimden 2.
    • The first of the 3 wires can easily be found and is connected to the board via a clip.
    • To remove the clip squeeze the tap and pull it out.
    • There are still 2 more wires connected to the board. Now that the first has been removed the other two can be more easily reached.
  4. Sony CPF-IP001 Power Plug Replacement: adım 4, 3 resimden 1. Sony CPF-IP001 Power Plug Replacement: adım 4, 3 resimden 2. Sony CPF-IP001 Power Plug Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The wire furthest to the left of the device can be removed in the same way that he first was removed. Simply squeeze the clip and pull out.
    • The final wire (furthest to the right) can be carefully removed using a pair of tweezers.
    • Now the circuit board has been completely removed from the device and can be set aside.
  5. Sony CPF-IP001 Power Plug Replacement: adım 5, 2 resimden 1. Sony CPF-IP001 Power Plug Replacement: adım 5, 2 resimden 2.
    • Next the housing for the power switch and power cord must be removed.
    • Remove the 4 XXXX screws using a Phillips #2 screwdriver.
  6. Sony CPF-IP001 Power Plug Replacement: adım 6, 3 resimden 1. Sony CPF-IP001 Power Plug Replacement: adım 6, 3 resimden 2. Sony CPF-IP001 Power Plug Replacement: adım 6, 3 resimden 3.
    • Remove these next 6 XXXX screws using a Phillips #2 screwdriver.
    • The housing is now disconnected from the device and can be pulled out from the side.
    • The power housing will come out as a whole unit with the subwoofer air tunnel.
  7. Sony CPF-IP001 Power Plug Replacement: adım 7, 1 resimden 1.
    • The subwoofer air tunnel can be removed by unscrewing the 2 XXXX screws with a Phillips #2 screwdriver.
Sonuç
Mike Bolton
473 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G14
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 268
