Ana içeriğe geç
Sony CPF-IP001 Subwoofer Replacement
Neye ihtiyacın var
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: adım 1, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: adım 1, 2 resimden 2.
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. Sony CPF-IP001 Subwoofer Replacement: adım 2, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 2, 2 resimden 2.
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
    FixBot'a Sor
    Yorum Ekle
  3. Sony CPF-IP001 Subwoofer Replacement: adım 3, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 3, 2 resimden 2.
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
    FixBot'a Sor
    Yorum Ekle
  4. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 2. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
    FixBot'a Sor
    Yorum Ekle
  5. Sony CPF-IP001 Subwoofer Replacement: adım 5, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 5, 2 resimden 2.
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
    FixBot'a Sor
    Yorum Ekle
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: adım 6, 1 resimden 1.
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
    FixBot'a Sor
    Yorum Ekle
  7. Sony CPF-IP001 Subwoofer Replacement: adım 7, 1 resimden 1.
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
    FixBot'a Sor
    Yorum Ekle
  8. Sony CPF-IP001 Subwoofer Replacement: adım 8, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 8, 2 resimden 2.
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
    FixBot'a Sor
    Yorum Ekle
  9. Sony CPF-IP001 Subwoofer Replacement: adım 9, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 9, 2 resimden 2.
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  10. Sony CPF-IP001 Subwoofer Replacement: adım 10, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 10, 2 resimden 2.
    • The subwoofer has now been removed from the device and can be replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mike Bolton
473 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G14
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 1,136
