Ana içeriğe geç
Sony CPF-IP001 Subwoofer Replacement
Neye ihtiyacın var
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: adım 1, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: adım 1, 2 resimden 2.
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
  2. Sony CPF-IP001 Subwoofer Replacement: adım 2, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 2, 2 resimden 2.
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Subwoofer Replacement: adım 3, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 3, 2 resimden 2.
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
  4. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 2. Sony CPF-IP001 Subwoofer Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
  5. Sony CPF-IP001 Subwoofer Replacement: adım 5, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 5, 2 resimden 2.
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: adım 6, 1 resimden 1.
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
  7. Sony CPF-IP001 Subwoofer Replacement: adım 7, 1 resimden 1.
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
  8. Sony CPF-IP001 Subwoofer Replacement: adım 8, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 8, 2 resimden 2.
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
  9. Sony CPF-IP001 Subwoofer Replacement: adım 9, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 9, 2 resimden 2.
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
  10. Sony CPF-IP001 Subwoofer Replacement: adım 10, 2 resimden 1. Sony CPF-IP001 Subwoofer Replacement: adım 10, 2 resimden 2.
    • The subwoofer has now been removed from the device and can be replaced.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mike Bolton
473 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G14
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 733
