Ana içeriğe geç
Sony Clie PEG-NR70 Battery Pack Replacement
Görüntüleme: 3,5 B
İstatistikleri görüntüle:
Son 24 Saat:
5
Son 7 Gün:
36
Son 30 Gün:
123
Her zaman:
3.510
Yorumlar: 2
2 guide comments.
Go to guide comments
Tamamlandı: 4
4 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: 10 dakika
Zorluk: Kolay
If your device is not holding a charge or simply will not turn on, it is possible that you need to replace the battery. This easy guide will take you through the necessary steps in order to remove the battery so you may install a new one.
Neye ihtiyacın var
Parçalar
Aletler
    1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: adım 1, 1 resimden 1.
      • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
      • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Clie PEG-NR70 Battery Pack Replacement: adım 2, 1 resimden 1.
      • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Clie PEG-NR70 Battery Pack Replacement: adım 3, 2 resimden 1. Sony Clie PEG-NR70 Battery Pack Replacement: adım 3, 2 resimden 2.
      • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
      • Remove the back panel by lifting it away with your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: adım 4, 2 resimden 1. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: adım 4, 2 resimden 2.
      • Pull up on the black tab on the battery pack to reveal the power cord.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Clie PEG-NR70 Battery Pack Replacement: adım 5, 1 resimden 1.
      • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
      • Be careful to not tear the cables! They are very thin.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Clie PEG-NR70 Battery Pack Replacement: adım 6, 1 resimden 1.
      • Gently peel back the adhesive to completely disconnect the battery pack from device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Courtney
65 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G11
5 Üyeler
96 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi, this is really helpful, thank you.
Richard Hancock - Yanıt Paylaş
Ismein display Se Le Gaye to kaise Sahi Karen
Nihal Alee - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 36
Son 30 gün: 123
Her zaman: 3,510
