Ana içeriğe geç
Sony Clie PEG-NR70 Speaker Rail Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-NR70 Speaker Rail Replacement, The Case: adım 1, 1 resimden 1.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Rail Replacement: adım 2, 1 resimden 1.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Rail Replacement: adım 3, 2 resimden 1. Sony Clie PEG-NR70 Speaker Rail Replacement: adım 3, 2 resimden 2.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: adım 4, 2 resimden 1. Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: adım 4, 2 resimden 2.
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Rail Replacement: adım 5, 1 resimden 1.
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
Sonuç
Daniel Soski
57 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G11
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 302
