Ana içeriğe geç
Sony Clie PEG-NR70 Speaker Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-NR70 Speaker Replacement, The Case: adım 1, 1 resimden 1.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Replacement: adım 2, 1 resimden 1.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Replacement: adım 3, 2 resimden 1. Sony Clie PEG-NR70 Speaker Replacement: adım 3, 2 resimden 2.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: adım 4, 2 resimden 1. Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Replacement: adım 5, 1 resimden 1.
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
  6. Sony Clie PEG-NR70 Speaker Replacement, Speaker: adım 6, 1 resimden 1.
    • Hold back the plastic tabs to pop the speaker out of the rail.
Sonuç
Daniel Soski
63 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G11
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 428
