Ana içeriğe geç
Sony Clie PEG-SL10 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: adım 3, 1 resimden 1.
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: adım 7, 1 resimden 1.
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: adım 8, 1 resimden 1.
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: adım 10, 1 resimden 1.
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: adım 11, 1 resimden 1.
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Sonuç
Emily
3 İtibar
3 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G4
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,299
