Ana içeriğe geç
Sony Clie PEG-T615C Battery Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-T615C Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: adım 2, 1 resimden 1.
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: adım 3, 1 resimden 1.
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: adım 4, 1 resimden 1.
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: adım 5, 1 resimden 1.
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: adım 6, 1 resimden 1.
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: adım 7, 1 resimden 1.
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: adım 8, 1 resimden 1.
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: adım 9, 1 resimden 1.
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: adım 10, 1 resimden 1.
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: adım 11, 1 resimden 1.
    • Remove the battery by sliding it out of the side of the device.
Sonuç
Rob
1 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Stout, Team 5-6, Zhou Fall 2011 UW Stout, Team 5-6, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 2,279
