Ana içeriğe geç
Sony Clie PEG-T615C Thumb Dial Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: adım 1, 1 resimden 1.
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: adım 2, 1 resimden 1.
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: adım 3, 1 resimden 1.
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: adım 4, 1 resimden 1.
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: adım 5, 1 resimden 1.
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: adım 6, 1 resimden 1.
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: adım 7, 1 resimden 1.
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: adım 8, 1 resimden 1.
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: adım 9, 1 resimden 1.
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: adım 10, 1 resimden 1.
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: adım 11, 1 resimden 1.
    • Pull plug straight up to remove from board.
Sonuç
Rob
1 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Stout, Team 5-6, Zhou Fall 2011 UW Stout, Team 5-6, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,067
