Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
Remove the screw from thumb dial panel on the right handed side of the device.
Remove 1 screw from the lower left side of the device.
On the bottom of the device, remove both the left and right screws.
Remove the thumb dial panel by sliding it away from the device.
Remove the back panel exposing the inside of the device.
Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
