Ana içeriğe geç
Sony Clie PEG-UX50 Rear Case Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-UX50 Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Tools Needed
    • Phillips Screwdriver
    • Tweezers
  2. Sony Clie PEG-UX50 Rear Case Replacement: adım 2, 3 resimden 1. Sony Clie PEG-UX50 Rear Case Replacement: adım 2, 3 resimden 2. Sony Clie PEG-UX50 Rear Case Replacement: adım 2, 3 resimden 3.
    • Using Phillips screwdriver, remove 4 screws from the rear cover.
    • Remove 1 screw from the right side.
    • Remove 1 screw from the top
  3. Sony Clie PEG-UX50 Rear Case Replacement: adım 3, 2 resimden 1. Sony Clie PEG-UX50 Rear Case Replacement: adım 3, 2 resimden 2.
    • Gently pry rear cover to remove USB port cover and Hold Switch.
  4. Sony Clie PEG-UX50 Rear Case Replacement: adım 4, 2 resimden 1. Sony Clie PEG-UX50 Rear Case Replacement: adım 4, 2 resimden 2.
    • Remove side cover.
    • Gently pull the rear cover to separate from device.
  5. Sony Clie PEG-UX50 Rear Case Replacement: adım 5, 1 resimden 1.
    • Slowly pull rear cover from device being careful not to pull the speaker connection wire.
    • Remove speaker wire from device.
    • The rear cover is now separated from the device.
Sonuç
Ekip
CSU Los Angeles, Team 1-4, Nelson Spring 2011 CSU Los Angeles, Team 1-4, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G4
5 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 4,085
