Ana içeriğe geç
Sony Clie PEG-UX50 Tilt Screen Replacement
Neye ihtiyacın var
  1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: adım 1, 3 resimden 1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: adım 1, 3 resimden 2. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: adım 1, 3 resimden 3.
    • Take off the screws located on the two sides of the tilt screen.
    • Unscrew the screw located at the tilt base of the screen.
  2. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 2, 3 resimden 1. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 2, 3 resimden 2. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 2, 3 resimden 3.
    • Gently remove the back plate of the tilt screen by sliding it upward.
    • With caution, lift the wires from the track in the back plate.
  3. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 3, 2 resimden 1. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 3, 2 resimden 2.
    • Disconnect the thin USB cable attached to the Integrated Circuit.
  4. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 4, 2 resimden 1. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 4, 2 resimden 2.
    • Detach the plastic black frame from in between the plate and the LCD.
    • Do not disconnect the display from the board yet.
  5. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 5, 1 resimden 1.
    • Disconnect the thin connector from the face plate using tweezers.
  6. Sony Clie PEG-UX50 Tilt Screen Replacement: adım 6, 1 resimden 1.
    • Quickly release and disconnect the thick cable with your hands.
Sonuç
Follow these instructions in reverse order to reassemble your device.
Rishad R Rai
1 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-4, Nelson Spring 2011 CSU Los Angeles, Team 1-4, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G4
5 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,732
