Ana içeriğe geç
Sony Cyber-Shot DSC-H1 Lens Replacement
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: adım 1, 1 resimden 1.
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 2, 3 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 2, 3 resimden 2. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 3, 2 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 3, 2 resimden 2.
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 5, 1 resimden 1.
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: adım 6, 2 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: adım 6, 2 resimden 2.
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 7, 3 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 7, 3 resimden 2. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 7, 3 resimden 3.
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 8, 2 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 8, 2 resimden 2.
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 9, 1 resimden 1.
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 11, 3 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 11, 3 resimden 2. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 11, 3 resimden 3.
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 12, 3 resimden 1. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 12, 3 resimden 2. Sony Cyber-Shot DSC-H1 Lens Replacement: adım 12, 3 resimden 3.
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Charlie Pugeda
505 İtibar
3 adet Kılavuz yazıldı
Baylor, Team S5-G4, Williams Spring 2018 Baylor, Team S5-G4, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S5G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,266
