Ana içeriğe geç
Sony Cyber-Shot DSC-TX30 Movie Button Replacement
Neye ihtiyacın var
  1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: adım 1, 2 resimden 2.
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 2, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 2, 2 resimden 2.
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 3, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 3, 2 resimden 2.
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Outer Shell: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 7, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 7, 2 resimden 2.
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 10, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 11, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 12, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 12, 2 resimden 2.
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 13, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: adım 13, 2 resimden 2.
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: adım 14, 3 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: adım 14, 3 resimden 2. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: adım 14, 3 resimden 3.
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: adım 15, 2 resimden 1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers, remove the movie button from the back casing of the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 332
