Ana içeriğe geç
Sony Cyber-Shot DSC-TX9 Flash Replacement
Neye ihtiyacın var
  1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: adım 1, 3 resimden 1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: adım 1, 3 resimden 2. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 2, 2 resimden 1. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 2, 2 resimden 2.
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 4, 2 resimden 1. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 4, 2 resimden 2.
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: adım 5, 3 resimden 1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: adım 5, 3 resimden 2. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: adım 5, 3 resimden 3.
    • Remove the two screws for the metal plate on the bottom.
    • Detach the no fuse ribbon cables by sliding them out.
    • Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Remove ribbons slowly and carefully or they WILL rip.
    • Screws are of Phillips type, head size Y0 and 0.3 mm in length.
  6. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 6, 3 resimden 1. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 6, 3 resimden 2. Sony Cyber-Shot DSC-TX9 Flash Replacement: adım 6, 3 resimden 3.
    Satın Al
    • Carefully remove the Memory card circuit board. You will then be able to see the flash with the capacitors connected.
    • Using tweezers, carefully remove the components. They are all connected together.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
Sonuç
Yegor Shea
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G3, Julie Spring 2017 UMass Dartmouth, Team S4-G3, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S4G3
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 322
