Ana içeriğe geç
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: adım 1, 1 resimden 1.
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 2, 2 resimden 1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 3, 3 resimden 1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 3, 3 resimden 2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 6, 2 resimden 1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 6, 2 resimden 2.
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 9, 2 resimden 1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 9, 2 resimden 2.
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 10, 2 resimden 1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 10, 2 resimden 2.
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: adım 11, 1 resimden 1.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dana Sanchez
69 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Leahy Fall 2014 USF Tampa, Team 1-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 68
Her zaman: 2,122
