Ana içeriğe geç
Sony Cyber-Shot DSC-W170 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: adım 1, 3 resimden 1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: adım 1, 3 resimden 2. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: adım 1, 3 resimden 3.
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 2, 1 resimden 1.
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 3, 1 resimden 1.
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: adım 4, 3 resimden 1. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: adım 4, 3 resimden 2. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: adım 4, 3 resimden 3.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 5, 1 resimden 1.
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: adım 6, 2 resimden 1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: adım 6, 2 resimden 2.
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 7, 3 resimden 1. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 7, 3 resimden 2. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 7, 3 resimden 3.
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 8, 2 resimden 1. Sony Cyber-Shot DSC-W170 LCD Replacement: adım 8, 2 resimden 2.
    • Gently push the connector through the hole to separate the LCD from the metal casing.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 34
Her zaman: 192
