Giriş
This guide will help you to replace the top panel on the Sony Cyber Shot DSC-W170.
If the shutter button or the power button are not working properly, the solution is to replace the top panel unit. Be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Neye ihtiyacın var
Remove the first side panel to the left of the LCD.
Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
Bu adımda kullanılan alet:Tweezers$4.99
Lift up the black bar on the top flat ribbon cable with tweezers.
Gently pull the flat ribbon cable until it disconnects from the lens assembly.
