Ana içeriğe geç
Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: adım 1, 3 resimden 1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: adım 1, 3 resimden 2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: adım 1, 3 resimden 3.
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 2, 2 resimden 2.
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 3, 1 resimden 1.
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 4, 2 resimden 2.
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 5, 3 resimden 1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 5, 3 resimden 2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: adım 5, 3 resimden 3.
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 930
