Ana içeriğe geç
Sony Cyber-shot DSC-H200 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 7, 2 resimden 1. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 9, 3 resimden 1. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 9, 3 resimden 2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: adım 9, 3 resimden 3.
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
Sonuç
1Rehber Yorum
Where can you purchase a new replacement monitor?
Butch Sullivan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 2,720
