Ana içeriğe geç
Sony Cyber-shot DSC-H200 SD Door Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: adım 1, 2 resimden 1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: adım 1, 2 resimden 2.
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 2, 1 resimden 1.
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 3, 1 resimden 1.
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 4, 2 resimden 2.
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 5, 2 resimden 2.
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 6, 1 resimden 1.
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 7, 1 resimden 1.
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 8, 2 resimden 2.
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: adım 9, 1 resimden 1.
    • Remove the door.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,547
